306 clocks weird gauge ??
anyone know what the MIN/MAX dial is for on the dash board (under the rev counter) :?
when you start the engine it sits at max and then drops down to min,
V6Exec
Re: 306 clocks weird gauge ??
Post by V6Exec »
Sould lilke the oil level gauge you get on D8s
406 Coupe S HDi
PP2000 clone interface
ah rite cheers mate,
im hoping its not oil preasure gauge, (all tho engine aint knockin yet -touches wood,
thanks, for the reply, :wink:
Most Pugs have an oil level indicator, they used to have two functions - showing oil level first and then doubling as an oil temp gauge.
I wish other manufacturers had this feature :frown:
ithink you might be right,
oil level gauge, altho its pretty useless if it is, once car is started its pretty much dead,
it looks like the car has got a broken gauge,
borrowed this pic off eghay
:arrowd:
The oil level only shows on ignition, once the engines running it won't show the level (you'd probably crap yourself if it did :wink: ). I'm surprised it doesn't double as an oil temperature gauge though but having said that the oil takes an age to warm up in this weather.
Welly wrote:I'm surprised it doesn't double as an oil temperature gauge though
I think posh D8 406's were the same.
Welly wrote:I wish other manufacturers had this feature :frown:
Perhaps they didn't think you needed anything else to worry about?
True, some manufactures don't even give you a coolant temperature gauge now :roll: :?
