Speedo accuracy
- wes1001
- Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Speedo accuracy
Does anyone know or have experience of how much changing from 15" to 17" rims will throw the accuracy of the speedo out by ? , and is it a plus gain , i.e. indicated 30 is real 33 or is it vice versa ?. Cheers, Wes.
- jameslxdt
in theory fitting larger wheels will mean, the gearbox will do less rotations at the same speed as it did with the smaller wheels
so the speedo will say your going slower than you actually are, but it will be so minimal i wouldnt worry about it
406 d8 speedo's are so inacurate too, my old diesel would say 70mph when it was actually 80mph
- DaiRees
- Site Admin
Here you go Wes, have a look at this.
Tyre Size Calculator
Basically it's the outer circumference of the tyre that's important. i.e the distance the tyre will roll for one complete revolution. If you're going to fit larger rims, you'll no doubt fit lower profile tyres, so keep the outer diameter (and therfore the cicumference) about the same and you'll have no problems.
- DaiRees
- Site Admin
- Blue406
- 406 Gimp
Thats not good!jameslxdt wrote:in theory fitting larger wheels will mean, the gearbox will do less rotations at the same speed as it did with the smaller wheels
My speedo always reads within 3mph of my true speed.
- DaiRees
- Site Admin
Yup they are exacltly the same outer diameter at the standard 195/65/15, but as the profile is a percentage of the width, the profile you'll need depends on the width you choose. e.g. if you went for a 205/17 instead of a 225/17 you'd need a 50 profile instead of 45 etc...speediepug406 wrote:[font=Comic Sans MS] [/font] Hi there in answer to your question i believe that 45 profile tyres are the correct size for a 17". I am using 225/45/17 on my 6 without any probs with rubbing(lowered 40mm) or the speedo being out.
