Service Box help please
could do with part number for fuel rail pressure sensor
vin number VF38ERHZF81184327 cheers ....
Re: Service Box help please
Servicebox shows a Diesel HP Sensorpuggy wrote:could do with part number for fuel rail pressure sensor
1920.7R which was replaced with 1920.SZ
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
cheers nutski , is that for the one that screws into the middle of the
fuel rail .
fuel rail .
Yeah, screws into the middle underside of the rail
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
After reading this, I just went out to my donor car and removed the rail with sensor attached, and injectors too. These will be heading to an eBay auction soon.
Thanks for the reminder to remove before scrapping car
What car is it off ginger a 90 or 110 if a 110 and the
number is the same any chance of buying the sensor ??
Its a 110. I've just put it in the shed but can check part number later. Alternatively, it came from VIN VF38ERHZF81541809 should you wish to check service box.
I don't think it will fit my 2.2 but its a shame to keep it on the car when it goes for scrap if someone else could use it.
Part is the right one, seems to be a common part for the 2.0 and the 2.2.GingerMagic wrote:Its a 110. I've just put it in the shed but can check part number later. Alternatively, it came from VIN VF38ERHZF81541809 should you wish to check service box.
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
cheers ginger , the number for the sensor is on the black bit ,
let me know tomorrow ginger .
Its hard to see the number, but I think its 0281 002 283.
There are other numbers but they are under a mark on the sensor so I have no idea what it says..
Hope this helps?
Hope this helps?
