Mondeo cig lighter fuse
my fuse blew for the cig lighter in my 53 plate mondeo
the only problem I have is I don't have a fuse box cover behind the glove box just an open fuse box so I don`t know where the correct fuse is and it doesn't say in the handbook
any help would be appreciated
thanks
thanks
- Bailes1992
Re: Mondeo cig lighter fuse
There isn't a cover for the fuse box behind the glovebox. It's all written on the back of the glovebox itself.
Thanks should have checked my self
also now my washer jets both front and rear have stopped can`t find on the diagram on the glove box where the fuse is
any ideas anyone
thanks
any ideas anyone
thanks
That sounds like a cascade failure
Are you not finding anything with Google? This any good? http://www.fordwiki.co.uk/index.php?tit ... nformation
wipers themselves are working just not the washers seems strange that they are not on a fuse
Says F90 for rear wiper but F95 wash/wipe? Ah, copied from Haynes, now it all becomes clear
Check both I guess, but I'd be surprised if either was correct.
f95 is for lights f90 for rear wiper
could it be the pump has packed in
Maybe, if it only has 1 that does both like the 406.
hi lozz thanks for the diagram I`ve replaced the fuse but still nothing would it be the washer pump that has packed in then
wipers front and back work perfect just no washer
it couid be the motor, that's a wheel arch liner off job ithink - iknow it was on the mk2s
not sure on the 3s.
not sure on the 3s.
