MOT advisory
D9406
2.2 16v
MOT advisory
Post by D9406 »
Just passed mot,third in a row with no issues, and received two advisories.
1. Undertrays fitted obscuring some underside components.
2.Engine covers fitted obscuring some engine bay components.
So what is going to happen when a car with fully enclosed bays go for the mot?
Discuss.
trem1
Re: MOT advisory
Post by trem1 »
yea i get these on my 407, I asked if i should remove them for the following year and was told 'theres no need' :roll:
Re: MOT advisory
its a common advisory item now,.
altho iconsider it as just stupid. its away of Mr mot tester saving himself from inspecting brake pipes etc
normaly says something like - Engine cover fitted preventing full inspection of engine blah de blah on the ones ihad.
ithink your mot tester is not very keen :wink:
Re: MOT advisory
Go to a different MOT tester.
God knows what he'd be like after opening the bonnet of this Lexus:
http://www.technologytell.com/in-car-te ... C11014.jpg
Re: MOT advisory
Theyre not allowed to remove anything.
so what they carnt see they carnt fail.
so iguess by them adding the advisory is there way of a disclaimer ,incase by chance car decides to burst a brake pipe/piss oil out
aday after test.
Re: MOT advisory
Re: MOT advisory
highlander wrote:Go to a different MOT tester.
No user serviceable parts inside :roll: At least it's got a dipstick which I hear aren't making their way into some bimmers now...
Are mot testers still allowed to open doors?
gumby6371
Re: MOT advisory
Post by gumby6371 »
I strongly suspect that under all those engine covers are a family of mice and a large wheel...it gets around new EU emissions regs!!!
davew
Re: MOT advisory
Post by davew »
it's not the mot testers fault they are told they are not allowed to remove covers to check under them.
Re: MOT advisory
Nor are they allowed to probe suspicious areas with screwdrivers (ahh, them were the days)
Re: MOT advisory
davew wrote:it's not the mot testers fault they are told they are not allowed to remove covers to check under them.
If the engine bay is like that from factory, then they shouldn't write this in as an advisory. Either that, or allow them to remove the undertrays to perform the inspections.
Imagine trying to explain that to the person you're selling your car to. Will they really believe you? In my mind, that advisory lowers the value of your car.
davew
Re: MOT advisory
Post by davew »
removing engine trays would cause all sorts of problems, half of all engine trays i've seen have missing bolts and fasteners, held on with zip ties ect , the mot testers would then be held accountable if anything goes wrong or they can't get them back on properly.
i agree it's a bit of a problem as there could be a brake pipe under there that is a about to burst and they won't see it.
