Leather wheel in earlier car?
fattail95
Post by fattail95 »
Hi there guys,
I have a 2001 half-mux 406, with the non leather steering wheel, as pictured:
Can I fit this later type steering wheel into the car? Will there be any airbag/fitment issues?
Many thanks!
Benjamin
pug406nz
Re: Leather wheel in earlier car?
Post by pug406nz »
The steering wheel will fit but you have to use your same airbag. When you take off the steering wheel, the complete horn/airbag unit will come out.
fattail95
Post by fattail95 »
pug406nz wrote:The steering wheel will fit but you have to use your same airbag. When you take off the steering wheel, the complete horn/airbag unit will come out.
Does the earlier airbag fit properly? It looks different to the one on the leather wheel?
Thanks!
fattail95
Post by fattail95 »
Actually, upon further inspection looks like my airbag will fit into the wheel just fine.
dirtydirtydiesel
Post by dirtydirtydiesel »
I don't see why you can't use the new air bag, but you might need to use pp2000 to 'allow' it in your car :roll:
gumby6371
Post by gumby6371 »
A friend of mine recently did a 'straightening' job on a C4 and replaced the deployed side air bags with ones from a breaker and it didn't throw up any errors.
He had the battery off for a good couple of days during the strip down and refit so the car probably forgot then relearned everything afterwards avoiding the need for any reprogramming.
In a nutshell I think if you replace like for like there shouldn't be a problem and make sure you leave the battery off for a good hour before unplugging anything, just don't sit in the drivers seat when you start the engine for the first time :supafrisk:
fattail95
Post by fattail95 »
Back again! Recieved the wheel today, and there are some differences between the two. The new leather wheel has a central hole at the bottom of the wheel, whereas my current wheel has two holes at "ten to two". Will it still fit ok? I only have my standard airbag, not the new one.
