Hi Benjamin.
Is the steering wheel in the picture the new one? It looks a bit tatty inside where the horn connects, but the wheel itself looks nice....
My 2002 has screw holes in the back too, but the airbag is removed by pushing a screwdriver through from underneath - same as my 2004 406. I should imagine the wheel is the same, its only the airbag which is different as far as I know.
Sorry, not much help - maybe go ahead and fit it when you have a spare 30mins and post up how you get on. Don't forget to disconnect the battery ( and don't forget the 3 minute rule ) and swap them over.
You need a T40 or T50 torx bit to get the wheel off, and leave the bolt in a couple of threads so you don't hit yourself in the face trying to pull the wheel off....
