This is not the ad just seeking advice what you guys think it could fetch to the right person. I will list what its been done to it and all i would say is that car is a 100 % sound!
so here it is details with my expenditure (within the last 10k miles) :
2004 January reg.53 2.2hdi SE saloon in white with 94k miles and full service history,
2 keys(master and flip), 11 months mot and tax.
Exterior
1. few panels and bumpers been resprayed to get rid of small dings / scratches, considering age and mileage paintwork i would say 8 out of 10
2. brand new colour coded GMP 17” alloys with correct offset so no spacers required, brand new Uniroyal Rainsport3 tyres
3. debadged including boot with electric button inside to open it
4. HID kit and leds all round
5. Original roof bars
Interior
1. Half leather interior in very good condition, very clean, just drivers seat only showing normal wear
2. Upgraded trimmed steering wheel and gear knob
3. Upgraded CD unit with bluetooth
4. Headliner in black and roof fitted DVD player with 2 wireless headphones
5. Professionally fitted oil pressure and boost gauges in white to match existing.
6. all led lights
7. all electrics spot on including aircon.
Mechanical
1. engine and running gear is excellent, fap removed with canister in place(mot pass), egr with piping removed, all other unneeded vacuum things removed with Nico pipe kit installed, reconditioned turbo at 70k miles, high pressure and map sensors upgraded with custom remap done by HDI master Srdan at ecuedit, car dyno’ed 181bhp with 435nm at 2200 rpm, usual 2.2 hdi flat spot removed turbo spools from 1500 rpm and has no smoke at all on any load, stainless exhaust system, K&N air filter, full oil service, timing belt with tensioners including bottom pulley and water pump, aux belt with tensioner.
2. upgraged 6 speed gearbox from similar car mileage (406 was at 83k, gearbox came from 88k car), new oil and all seals
3. new Valeo SMF/clutch kit with required bearings (no vibrations)
4. bottom engine mount
5. new driveshafts
6. new Bilstein B4 shockers x4, new original spec. springs
7. new sport drilled and painted brake disks x4 with pads, new hand brake shoes
8. new braided brake hoses x4
9. new rear bearing/abs ring hubs x2
10. rest suspension is spot on
i feel insane now even considering to write this , jeez how much i spent
we did 2 separate road trips from Edinburgh one to Sicily, another to Cote D’azur – not a single glitch!
so what you guys think, 3.5k achievable? i spent so much more than that.....
