xud11bte info
Uberderv
xud11bte info
Post by Uberderv »
Hi,
Over the years I've collected various technical documents about the DW10TD and XUD9TE. Since I'm now the proud owner of a 2.1td I would like to collect some XUD11BTE info, in electronic form, if anyone can point me in the right direction I'd be most grateful :mrgreen:
Re: xud11bte info
Uberderv
Re: xud11bte info
Post by Uberderv »
Perfic thanks :)
Has anyone ever found owt similar to this http://www.christiantena.pwp.blueyonder ... operation/ for the XUD11 ?
Re: xud11bte info
Not for the XUD11, I found one for the DW12 years ago.
Do you know who 'owns' the link you posted? I'd like to add it to the Knowledge Base, but don't want to upset anyone in the process.
Rolebama
Re: xud11bte info
Post by Rolebama »
I've been collecting stuff since Dec 13, and there doesn't seem to be a lot out there. I have the Lucas Service Document for EPIC in pdf format which I would happily send to you as well as a couple of other items about epic.
1998 2.1 GLX TD
Uberderv
Re: xud11bte info
Post by Uberderv »
Doggy- It's been a long time since I spoke to the guy, I can try and get hold of him if you like?
Rolebama- Yes please send it. Anything that aids my tinkering obsession is most welcome. :mrgreen:
Rolebama
Re: xud11bte info
Post by Rolebama »
The suspect multi-connector in the event of an electrical non-start is the brown round connector directly under the battery tray. Apparently they can short across connections in a heavy downpour, and corrode.
The dual relay beside the ECU is a bitch to remove, but worth checking that there are three battery lives going to the connector. That was the problem for my non-start earlier this year. There is a 'map' of the connections embossed on the dual relay cover for checking. (Very useful that was, as one of them had broken. A direct feed through a 10-amp fuse was the repair option I went for.)
1998 2.1 GLX TD
