.....meant some work on the 406 estate before I go to Blackpool for the weekend.
1st job,
Replace the broken plastic rear drop links which only been on since June!
http://i59.photobucket.com/albums/g291/ ... 111322.jpg
To replace with nice metal 1's :-)
http://i59.photobucket.com/albums/g291/ ... 111352.jpg
http://i59.photobucket.com/albums/g291/ ... 111336.jpg
Next job, blank egr off, with help from a mate we had this done in 5 min :-D
http://i59.photobucket.com/albums/g291/ ... 132525.jpg
Then I fitted some little blue led lights to centre console to illuminate under the stereo and the rear footwells
http://i59.photobucket.com/albums/g291/ ... 001607.jpg
http://i59.photobucket.com/albums/g291/ ... 001640.jpg
Then gave her a good clean up, put her bonnet bra on and ready to go to Blackpool later today for the weekend with the better half :-)
A week off work.......
Re: A week off work.......
Looks great! Good job
Why don't you change the colour of the clocks/mfd/aircon too? There are blue conversion kits available and with a bit of soldering experience it's apparently quite easy, would look the mutts nuts too. On another note, if you haven't already, put a no-EGR map on the ECU for even better throttle response and MPGs, HDi tuning will modify your current map for £20, well worth doing IMO.
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
Cheers, thinking of the stage 2 map on it for 100, got all gear to take current map off and put another map on. The blue is something I was tempted on but gonna buy spares and do a tester 1st to be safe ;-)
