Scratch that'.
ifound another door and got it to work, abiet like service box, (not much use in this country,)
Vehicle Equipment
FLC73 ENGINE: INJECTION ET3J4
FL4E6 DIESEL FILTER WATER DETECTOR: WITHOUT DIESEL FILTER WATER DETECTOR
FL4A5 FUEL: LEAD FREE PETROL
FLD4B ENGINE TYPE: ENGINE TYPE ET
FL0C8 CATALYTIC CONVERTER: 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
FL3D7 COOLING MOTOR: RADIATOR TH : 18-16 DM2 ALUMINIUM MECHANICAL
FL90D CRANKCASE GAS CIRCUIT HEATING: WITHOUT HEATER CASING GAS CIRCUIT
FL4E5 DIANOSTIC SYSTEM: "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
FL41B ANTI-POLLUTION SYSTEM: WITHOUT ANTI-POLLUTION DEVICE
FL890 VEHICLE TECHNICAL DEPOLLUTION: L5 VEHICLE TECHNICAL DEPOLLUTION
FL36A PARTICLE FILTER: WITHOUT PARTICLE FILTER
INT34F FAN: 1 AERO 2-SPEED 90W FAN
FL763 FUEL VAPOUR RETRIEVAL: CONTROLLED PETROL VAPOUR RECUPERATION
FL103 TANK FILTER: RESERVOIR FILTER INTERIOR
FL795 STOP AND START: WITHOUT STOP AND START
GBF12 TRANSMISSION: BVM5
GB74E GEARBOX TYPE: BVM MA5 / N
GB268 FINAL DRIVE RATIO: REAR AXLE HYPOID GEARSET 13 X 59
GB0F9 SPEEDOMETER DRIVE: WITHOUT TACHO TORQUE
GB344 WHEEL STYLE: STEEL 6 J15 4-23
GB201 RIM/TYRE SIZE: 15 INCH TYRE FITMENT
GBEC9 WHEELS FITTED: 6" RIM ROAD WHEELS
INT1A1 INFLATION PRESSURE LOSS INDICATOR: WITHOUT TYRE DEFLATION INDICATOR
GB2A6 GEARBOX TYPE: MA
SSB1F9 ABS: WITH ABS BRAKES
SSB0B5 FRONT ANTI-ROLL BAR: FRONT ANTI-ROLL BAR DIAM 20
SSB361 BRAKE TYPE: VENTILATED FRONT DISCS/REAR DRUMS
SSB1E4 STEERING TRAVEL: STEERING MECHANISM TRAVEL 72
SSB7EC SUSPENSION: NORMAL SUSPENSION
SSB87F DYNAMIC STABILITY CONTROL SYSTEM: WITHOUT ELECTRONIC STABILITY PROGRAM
SSB1DF BRAKE ASSOCIATED VARIANT: ABS TEVES MK70
EL951 HORNS: HORN STANDARD
BD0CE OPENING ROOF (APPEARANCE): WITHOUT SUN ROOF
BDA51 REAR SPOILER: ASSEMBLY WITHOUT REAR SPOILER
BD754 SIDE MOULDINGS TYPE: LATERAL PROTECTOR MASS TINTED
BDE9C UNDERBODY SHIELD: WITHOUT PROTECTION UNDER BODY
BD333 UNDER ENGINE ADDITIONAL SHIELD: WITHOUT ENGINE UNDERSHELDING
EL4FD REARVIEW MIRROR FUNCTION: EXT MIRROR MANUAL-FOLD BACK
BDF4A EXHAUST TAILPIPE TRIM: WITHOUT EXHAUST OUTLET EMBELLISHER
BDBD9 ENGINE BAY SOUNDPROOFING: WITHOUT SOUND-PROOFING
BDBFB WINDSCREEN WIPER: FRONT WIPER BLADE WITHOUT RAIN SENSOR
BD0DD HEADLAMP WIPER: WITHOUT HEADLAMP WIPER
BD742 REAR SCREEN WIPER (OPERATION): INTERMITTENT REAR WIPER AUTO OPERATION
BD8F1 FRONT PANEL BLANK: WITHOUT FRONT BUMPER PLUG
BDB6B ROOF GLASS: WITHOUT ROOF WINDOW
BD5DF REAR TAILGATE GLASS: FIXED TAILGATE WINDOW
BDE83 OUTSIDE TEMPERATURE SENSOR: WITH EXTERIOR TEMPERATURE SENSOR
BD6B9 BUMPER: BODY COLOUR STANDARD FRONT/REAR BUMPER
BDCBE LUGGAGE RACK: WITHOUT ROOF BARS
EL6A2 FRONT FOGLAMP: NO FRONT FOG LIGHTS
EL104 SPECIAL HEADLAMP (DOUBLE OPTIC): DOUBLE OPTIC LAMPS
BD6E0 REAR VIEW MIRROR ON DRIVER SIDE: DRIVER’S DOOR MIRROR ELECTRIC CONTROL
BD9A8 REAR VIEW MIRROR ON PASSENGER SIDE: PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
BDB6D SPARE WHEEL: STEEL WHEEL + STANDARD TYRE
BD631 EXTERIOR ACCESSORIES: BODY COLOURED EXT HANDLES + EXT MIRROR
INTF71 REAR VIEW MIRROR - DRIVER SIDE RADIUS: CONVEX EXTERIOR MIRROR GLASS
BD634 SUN ROOF: FIXED ROOF
BD4DD BUMPER TRIM: DYED BUMPER STRIP
INTC9E WINDOW TYPE: LAM W/SCREEN + SIDE + RR TOUGHENED
BDF1B HANDS FREE ACCESS AND STARTING: NO ACCES AND HANDSFREE STARTING
INT89E ANTI-THEFT ALARM: WITHOUT THEFT PROTECTION ALARM
INT79C REAR HEAD RESTRAINT: REAR HEADREST ADJUSTABLE
INTDC6 FRONT HEAD RESTRAINT: JOINTED FRONT HEADREST
INTBCE REAR SEAT: SEPARATE FOLD BACK BENCH SEAT
INT25F LUGGAGE COVER: SHELF
INTC0A REAR SEATBELT: 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
INT8CA FRONT SEATBELT: DRIVER + PASSENGER SEATBELT WARNING
INTB68 CHILD LOCK: WITHOUT CHILD LOCK
INT56C SPEED GRADUATIONS: GRADUATION MPH
INT020 GRAB HANDLES: FR + RR HANDLES WITH HOOKS
INTB52 RADIO EQUIPMENT: FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
INTC24 DRIVING POSITION: RIGHT HAND DRIVE
ELD78 REMOTE CONTROL: REMOTE CONTROL ASSEMBLY
EL09F LOAD SPACE LIGHTING: GLOVE-BOX LIGHTING
INT20D DASHBOARD EQUIPMENT: MISTRAL LION GREY DECOR SOFT FASCIA
EL563 MISC. INTERIOR LAMPS: WITHOUT MAP READING LAMP
INT593 INSTRUMENT PANEL (CHARACTERISTICS): GRAD 220 KM/H 140 MPH BLACK BACKGND CHROME CIRCLE
INT7D1 SPEAKERS: 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
INTA66 RADIO CONTROLS: REMOTE RADIO CONTROL
INTE2F PASSENGER COMPARTMENT SOUNDPROOFING: 5KG BULKHEAD SOUNDPROOFING
INT29A FRONT PASSENGER SEAT HEIGHT CONTROL: FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
INT4AD DRIVER SEAT CONTROL: MEMORY CTRL DRIVERS FRONT SEAT
INT88B FRONT PASSENGER SEAT CONTROL: FRONT PASSENGER SEAT CONTROL WITH MEMORY
INTF60 DRIVER SEAT ADJUSTMENT: RECLINING DRIVER’S SEAT BACK
INT4DA FRONT PASSENGER SEAT ADJUSTMENT: PASSENGER TILTING BACK
INT247 FRONT SEAT ARMREST: ASSEMBLY WITHOUT FRONT ELBOW REST
INTF9C ROOF CONSOLE: WITHOUT ROOF CONSOLE
INT6DE COMPACT DISC: WITHOUT COMPACT DISC
INT8DB NAVIGATION SYSTEM: WITHOUT NAVIGATION SYSTEM
EL727 HEADLAMP: HALOGEN BULB
INT6AC REAR WINDOW LIFT: WITHOUT REAR GLASS LIFT
INT725 DRIVER’S WINDOW LIFT: SEQUENTIAL DRIVER’S ELECTRIC WINDOW
INTC7C PASSENGER’S WINDOW LIFT: ELEC CNTRL PASS FRONT WINDOW LIFTER
INT3F2 DISPLAY: DISPAY (RADIO+CLOCK+AND OR TO, CD) WITHOUT MEMORY
INT00C COURTESY MIRROR: DRIVER’S CONCEALABLE+PASS NON CONCEALABLE NO LIGHT
INTDAE OIL GAUGE: STD OIL LEVEL INDICATOR
INT8B3 FITTING REAR HEAD RESTRAINT: MOUNT 3 REAR HEAD-REST
INTE7C HEATING ELEMENT: NON HEATED SEAT
INT267 FRONT LATERAL AIRBAG: THORAX SIDE + CURTAIN AIRBAG
ELFFA FOOTWELL LIGHTING: WITHOUT DOOR SILL LIGHTING
INTEF1 PASSENGER AIRBAG: WITH PASSENGER AIRBAG
INTD19 ON-BOARD COMPUTER: COMPUTER
INTED1 EXTERIOR REAR VIEW MIRROR (HEATED): HEATED DOOR MIRROR
INT8C5 AIRBAG DEACTIVATION: MANUAL AIRBAG DEACTIVATION
INTCC3 INTERIOR DOOR CONTROL: INT DOOR HANDLE GREY LION
ELD8A COURTESY LAMP: DOORS + FR COURTESY LIGHT REMOTE CONTROL
EL785 DIRECTIONAL HEADLAMP: WITHOUT DIRECTIONAL LIGHTS
INTB6D FRONT SEAT GUARD: WITHOUT SEPARATION GRILLE
INTCC6 STORAGE ON DRIVER POSITION: LOWER STORAGE COMPARTMENT WITH LOCK + COOLED
INTC5D RADIO TYPE: "RD4" RDS COMPACT DISC AUDIO SYSTEM
INT82B AIR CONDITIONING: SINGLE AIR CONDITIONING
INT502 CRUISE CONTROL: WITHOUT SPEED CONTROL
INT7CD DRIVER’S SEAT HEIGHT CONTROL: PARALLEL DRV HEIGHT ADJ
INT3DE INTERIOR REAR VIEW MIRROR: DAY -NIGHT INNER REAR MIRROR - WITHOUT ELECTROCHRO
INTE39 OTHERS STORAGE: WITHOUT OTHER SETTING BOXES
INTAEE CARPET COVER: WITHOUT CARPETMAT
INT1E9 DRIVER AIRBAG: DRIVERS AIR BAG
INTF8B LOAD SPACE STORAGE: WITHOUT BOOT TIDY
INT0BB TUNER RADIO: MONO RADIO TUNER
INT9EA INTERIOR PROTECTION: WITHOUT INNER PROTECTION
INT55A SCALE OF EXTERIOR TEMPERATURE: EXT TEMP INDICATOR CELSIUS
INT014 OBSTACLE DETECTION SYSTEM: WITHOUT OBSTACLE DETECTOR
INT0F4 EQUALISER AMPLIFIER: WITHOUT EQUALISER AMPLIFIER
INTD82 LOCKING CONTROL: DEADLOCKING + AUTOMATIC LOCKING
INT4A3 STORAGE SPACE LOCKS: LOCKING GLOVEBOX
INT313 AMBIENCE PACK: WITHOUT AMBIANCE PACK
INT867 DRIVER’S KNEE AIRBAG: WITHOUT DRIVER’S KNEE AIRBAG
EL76B ALTERNATOR: ALTERNATEUR CLASSE 8+
EL812 BATTERY: BATTERY L2 400
ELAF5 STARTER MOTOR: STARTER MOTOR CL 2
ELD36 SPECIAL LIGHTING: WITHOUT PARTICULAR LIGHT
EL70E RADIO FREQUENCY: WESTERN EUROPE RADIO FREQUENCY
CP1DF BRAKE ASSOCIATED VARIANT: ABS TEVES MK70
MSC24 DRIVING POSITION: RIGHT HAND DRIVE
MSBE8 RADIO HEADPHONE SOCKET: WITHOUT ACCESSORIES SOCKET
MSEBA TRAFFIC SIDE: DRIVING ON THE LEFT-HAND SIDE
MS621 SET OF KEYS: 2 HF PLIP KEYS
MS783 EMERGENCY EQUIPMENT: WITHOUT HELP EQUIPMENT
MS631 EXTERIOR ACCESSORIES: BODY COLOURED EXT HANDLES + EXT MIRROR
MS2E0 SPEED MONITORING: WITHOUT SPEED CHECK
Damage History
NO DATA
Mileage History
NO DATA
Internet History
2006-09-27
Description Vehicle release/build date.
Services History
NO DATA
Check History
NO DATA
Databases of stolen vehicles
Register of stolen vehicles of Canadian Police No entry
Internet register of stolen vehicles CrimiMail No entry
Register of stolen vehicles of Czech Police No entry
Internet register of stolen vehicles Germany No entry
Internet register of stolen vehicles Norway No entry
Register of stolen vehicles of Italian Police No entry
Internet register of stolen vehicles Kaynine No entry
Register of stolen vehicles of Lithuanian Police No entry
Register of stolen vehicles of Dutch Police No entry
Register of stolen vehicles of Romanian Police No entry
Internet register of stolen vehicles Sweden No entry
Register of stolen vehicles of Slovenian Police No entry
Register of stolen vehicles of Slovak Police No entry
Register of stolen vehicles IAATI / VIN-Info No entry
Production Defects
NO DATA
