Best way to paint Brake Disc hubs?
I can has new brake discs but this time I wanted to take some time before they're fitted to paint the hubs and hopefully the outer edges of the discs to stop them rusting.
I was thinking of Silver VHT rattle-canning but it's going to be hard masking up. What about greasing the disc braking surface so the overspray won't stick and then cleaning off with brake cleaner after the paint dries?
Suggestings welcomes.
Uberderv
Re: Best way to paint Brake Disc hubs?
Post by Uberderv »
Cover the whole disk in masking tape then cut the edges/parts to be sprayed off with a knife. They usually have an oily layer so clean first. VHT paint or BBQ paint should work...
Bailes1992
Post by Bailes1992 »
I just spray the entire disc.
Any paint on the disc where it makes contact with the brake pad will come off anyway.
In fact pagid discs come from the factory entirely painted.
Bailes1992 wrote:I just spray the entire disc.
Thats what I did with my rear discs, primer, silver, lacquer, and they are still silver after 2 years - as Sam says the pads just rub the paint off where it matters...
I spoke too soon, I received the discs and I can has a surprise:
Packaging:
Ooo:
WooHoo, pre-painted discs:
And some Ford Drop Links :roll: :
Welly wrote:Ford Drop Links
calvi36
Post by calvi36 »
I did this job last week before the new rear discs were fitted. You will need high temp primer and high temp paint. Just clean off the excess film of oil and mask the outer area of the disc.
old disc
Paint I used
Prepped
Painted.
Owned:
3.0 V6 Estate D8- Killed by a drunk driver outside my home!
2.2 HDi Coupe Ariane Blue- Exported and now lives in Germany.
3.0 V6 Coupe D9 Polaris Blue- Sold to another Scotsman.
3.0 V6 Coupe D8 Polaris Blue- Still owned.
3.0 V6 Coupe D9 Pulsar Yellow- Still owned.
407 SW 2.0HDi Executive- Daily wagon, still owned.
