Check out your old motor (MOT check site)
This Gov website is now running https://mot-history.net/ and I just checked out me old T-reg 406 HDi Exec
Looks like it was finally retired in March but it's not been easy to live with since I sold it
MOT history of this vehicle
Test date17 March 2014 Expiry date24 March 2015 Test ResultPass Odometer reading158,812 miles MOT test number3691 1687 4092 Advisory notice item(s)
Supplementary Restraint System warning lamp does not illuminate (5.4.2)
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Front Brake pad(s) wearing thin (3.5.1g)
Nearside Rear Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Nail in offside front tyre
Test date14 March 2014 Test ResultFail Odometer reading158,810 miles MOT test number7970 3307 4026
Reason(s) for failure
Rear Exhaust has a major leak of exhaust gases (7.1.2)
Emissions not tested (7.0)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Parking brake: efficiency below requirements (3.7.B.7)
Test date25 March 2013 Expiry date24 March 2014 Test ResultPass Odometer reading155,952 miles MOT test number4376 5488 3079 Advisory notice item(s)
Steering system slightly rough (2.2.D.1)
Oil leak
Under-trays fitted obscuring some underside components
Engine covers fitted obscuring some components in the engine bay
Spare tyre defective
Test date21 March 2013 Test ResultFail Odometer reading155,950 miles MOT test number6886 6018 3024
Offside Outer Front constant velocity joint gaiter deteriorated to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
Oil leak
Test date28 February 2012 Expiry date2 March 2013 Test ResultPass Odometer reading150,765 miles MOT test number4564 1965 2082 Advisory notice item(s)
Headlamp deteriorated but light output not reduced (1.7.5a)
Oil leak
Test date3 March 2011 Expiry date2 March 2012 Test ResultPass MOT test number9472 6246 1058 Advisory notice item(s)
Offside Front Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Parking brake lever has little reserve travel (3.1.6b)
Test date1 March 2011 Test ResultFail MOT test number9596 0016 1005
Nearside Rear Tie bar/rod has excessive play in a ball joint (2.4.G.2)
Offside Rear Tie bar/rod has excessive play in a ball joint (2.4.G.2)
Test date14 January 2010 Expiry date13 January 2011 Test ResultPass MOT test number6337 9481 0058 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Test date11 January 2010 Test ResultFail MOT test number7823 1121 0007
Offside Rear coil spring incomplete (2.4.C.1a)
Fuel system component leaking (7.2.3)
Test date15 December 2008 Expiry date10 January 2010 Test ResultPass MOT test number1847 8065 8304 Advisory notice item(s)
Offside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a)
Nearside Rear Upper Trailing arm has slight play in a pin/bush (2.4.G.2)
Oil leak
Test date9 January 2008 Expiry date10 January 2009 Test ResultPass MOT test number1532 4940 8051 Advisory notice item(s)
Offside Rear Upper Suspension arm has slight play in a pin/bush (2.4.G.2)
Test date8 January 2007 Expiry date10 January 2008 Test ResultPass MOT test number3201 6870 7019
Test date11 January 2006 Expiry date10 January 2007 Test ResultPass MOT test number9334 7111 6072 Advisory notice item(s)
Oil leak
Oil leak
Oil leak
Oil leak
Re: Check out your old motor (MOT check site)
Phew...
That facility is rather neat now. I'm sure that previously the only people
who could check the MOt history was whoever could quote the 'document number'
from the V5.
from the V5.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Indeed all you need is the reg. Time to check out next doors' sh1t 2003 Discotrufflehunt wrote:Phew...
from the V5.
- waue1978
- HDi don't believe it!
I'm bloody fuming. My 406 cost me £2-300 every MOT that I had it, but once I sold it on it sailed through every one - check X745EBY (the original registration). It's now on over 140k.
- Bailes1992
A bit annoyed. The ST220 I've been trying to track down for the last 2 years seems to have been scrapped January last year.
I've just checked both mine and t'wife's cars - I mustard mitt I'm happy with the results for both, the worst issues being pitted brake discs and not 'orange enough' indicators....
This check facility will have an impact on used car sales places I fink; as per me turning up at Evans Halshaw yesterday to look at an i10 for MIL armed with its MOT history to be fair the young chappy was a bit surprised but not really phased by it (2010 car).
I'm quite pleased me old 406 soldiered on for another 6 years but by god it put up a fight
- rwb
Looks like my 406 has gone Although the site seems to think it's petrol
Although it put in a pretty respectable 215k over 13 years.
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle make: PEUGEOT
Vehicle model: 406
Date first used: 30 October 2000
Fuel type: Diesel
Colour: Blue
Test date: 7 October 2015
Test Result: Fail
Odometer reading: 137,276 miles
MOT test number: 9420 8310 4119
Reason(s) for failure:
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Expiry date: 6 October 2016
Test Result: Pass
MOT test number: 5760 6915 5673
Test date: 30 September 2014
Expiry date: 29 September 2015
Test Result: Pass
Odometer reading: 134,205 miles
MOT test number: 4795 7377 4205
Advisory notice item(s):
Nearside Front Direction indicator slightly discoloured (1.4.A.2f)
Offside Front Direction indicator slightly discoloured (1.4.A.2f)
Nearside Side repeater slightly discoloured (1.4.A.2f)
Offside Side repeater slightly discoloured (1.4.A.2f)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Test date: 27 September 2013
Expiry date: 27 September 2014
Test Result: Pass
Odometer reading: 129,686 miles
MOT test number: 1855 5027 3237
Offside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Test date: 28 September 2012
Expiry date: 27 September 2013
Test Result: Pass
Odometer reading: 125,931 miles
MOT test number: 6957 9267 2243
Test date: 28 September 2011
Expiry date: 27 September 2012
Test Result: Pass
Odometer reading: 120,937 miles
MOT test number: 7957 0157 1231
Test date: 23 September 2010
Expiry date: 26 September 2011
Test Result: Pass
MOT test number: 6947 6646 0251
Test date: 24 September 2009
Expiry date: 26 September 2010
Test Result: Pass
MOT test number: 8434 6746 9232
Test date: 19 September 2008
Expiry date: 26 September 2009
Test Result: Pass
MOT test number: 6803 6336 8267
Test date: 15 September 2007
Expiry date: 26 September 2008
Test Result: Pass
MOT test number: 3113 0845 7499
Test date: 1 September 2006
Expiry date: 26 September 2007
Test Result: Pass
MOT test number: 7920 6464 6259
Test date: 15 August 2006
Test Result: Fail
MOT test number: 5632 5792 6272
Offside Rear Tie bar/rod has excessive play in a pin/bush (2.4.G.2)
Centre Front Exhaust has a major leak of exhaust gases (7.1.2)
Front Exhaust has part of the system excessively deteriorated (7.1.1a)
Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
Test date: 27 September 2005
Expiry date: 26 September 2006
Test Result: Pass
MOT test number: 7243 1087 5238
Vehicle model: 406
Fuel type: Diesel
Colour: Blue
Test Result: Fail
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Pass
Test Result: Fail
Test Result: Pass
Good job it doesn't record the blood sweat and tears inbetween mot's
They could have been exported like the two I have. No mention of that in the MOT . Very handy site for prospective buyer.
- rwb
Hey puggy. great to see you. hope all is well.
Yes not too bad thanks and you ?
