Evening all,
Want to replace my power steering fluid in the '6 as it's looking a little dark and old. I was recommended Fuchs Titan ATF 4000 by Opie Oils, just wanted to verify with you guys that it is suitable?
http://www.opieoils.co.uk/p-965-fuchs-t ... fluid.aspx
It is rated as DEXRON 3 which I think is the correct fluid for the job? Only thing that has me worried is that it's called automatic transmission fluid, but I don't have much experience with PAS systems so I might be quite wrong.
Best Regards
Ben
Power steering fluid?
150hp/330nm • Powerflow stainless exhaust • Kevlar clutch • Cat delete • EGR & Doser delete • Leather interior • Windows tinted • Cruise control • 5 dial cluster • Yatour bluetooth • Starfish alloys • Twin rear fogs
Re: Power steering fluid?
My car's up at my gaff so I can't look but I'm pretty sure it says what to use on the lid. Dextron 2 maybe? Automatic transmission fluid is generally what goes in power steering.
