How do 406's deal with the cold?
406Break
Post by 406Break »
DJCy8SomeEw
My pug resets the date and clock if it's below -15 Celsius. But starts fine I guess... Battery: few years old, 12V/62Ah/540A
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
Re: How do 406's deal with the cold?
Couidnt-load- plug-in?.
Iwouid get battery tested..
PeterN
Post by PeterN »
Sounds like the battery voltage is dropping very low on start up, as Lozz says I think a new battery is in order.
jonsowman
Post by jonsowman »
UK spec diesel can start to gel at -15C odd. Additives can take this to around -25C I believe, but this might be responsible for the starter having to work a lot harder than normal.
Still, I'd get the battery tested as a first step :)
Judging by the tacho scale, I'd say the OP's car is petrol
I agree it's most likley a failing battery
406Break
Post by 406Break »
OR too small battery?
Car: 406 Break - 2.0L 99kw petrol
Yes, it could be too small - if you post the VIN, we should be able to check the original battery spec.
Our* 1.6HDi sounded a bit unnecessary at 0 deg C starting, it's on a new battery funded by the Bank of Wellington but did a few little coughs at first, bless it.
Doggy wrote:Yes, it could be too small - if you post the VIN, we should be able to check the original battery spec.
Using a semi-mux 2.0 RFN vin - L1-300-480A-50AH
406Break
Post by 406Break »
VF38ERFRE80937145
Ah balls, RFR, sorry. Oh, I already have your vin code (I just didn't put a note to say whose car it was)
Umm, BATTERY L2 400
There are loads on the parts diagrams but I think this is the one L2 400/60
406Break
Post by 406Break »
So my current battery exceeds factory recommendations?
But in any case, do you think the problem might be one of three:
1. Battery is getting old
2. Low capacity
3. Low cold cranking current
I'd think all 3, it's the most likely part of the system, followed by a bad connection somewhere.
How old is the battery?
Mine crapped out and died one frosty morning last January/February. It was fine the day before, and when I went to start it, it just went "Meh" and refused. The dash lights came on for a few seconds, and almost no response from the turn of the key.
I replaced it myself with a Yuasa silver battery of the recommended size for my car, and it instantly fixed the problem.
406Break
Post by 406Break »
Maybe I should check the earthing connections on the car... A bad ground/earth can also lead to such problems?
Next year, new battery. This year maybe won't get -20C anymore. Above -15, everythings fine.
Battery: few(maybe 3) years old, 12V/62Ah/540A
