I have a 240 > 12v transformer up in the loft (rated to suit 5No. 20 watt GU5.3 lamps). The 5 x lamps are wired in parallel.
The problem: The lamps are slower than before in lighting up, just a short delay, the last one on the line is dimmer than the first (progressively worse along the line) and the transformer is hot. Not only that but the first meter of 12v wiring to the first lamp is worryingly warm
What could be going on? too much current draw? transformer failing? why the hot cable?
On the strength of what I found I'm ripping them out at the weekend and converting to 240v LED but just want to better understand what's going on.
