dirtydirtydiesel wrote: ↑Wed Feb 24, 2021 7:59 pm
The main difference between a 90 & a 110 is one is Bosch fueling & ecu controlled turbo (110)
with the aforementioned intercooler and pipework.
A 90 is Siemens fueling & mechanical boost control with no intercooler.
HDi tuning can supply you two levels of re-map 1st 125bhp no supporting mods needed
or up to 150bhp , you need to fit a intercooler, remove the cat ect.
Have a read up on there website.
You want 20mm hubcentric spacers all round with those Challengers, a 40mm drop would massively improve
the look & handling as well.
A coupe front strut brace is a cheep bolt on mod that sharpens up the front end & improves turn in.
Leather interior for an estate, good luck finding that.
They are out there but just try finding it
Thanks for your reply DD,
I absolutely agree with the challengers comment, I’ve got 5mm on there at the moment just so it clears the calliper but need to fork out for the 20’s and nuts, I’ve found them for about 90 quid all round on eBay.
I have seen the hdi tuning website, those guys seem will be a useful company coming forward.
Haha yeah, I’ve tried finding the interior but I’m more likely to buy a donor car before finding the seats by themselves
These comments are great though, thank you all..
Like I mentioned I don’t need to go crazy, just a couple of nice upgrades.
It’s good to know the coupe strut brace fits too.. I’ve looked at parts from a coupe but was a bit uncertain, hence this website!
You mentioned about lowering, I’ve seen a set of coil overs that I might invest in once the 18s come along.. they do 40 on the front and up to 100 at the back, don’t think I’ll go much lower as the front end is already catching kerbs and larger bumps, like Peter says, the ride is good in here and I don’t want to go to far!
