Discuss possible outcomes
I managed to get 4th instead of 6th at a supersonic speed in the 6 once, with French gearboxes anything is possibleWelton wrote:Now come along Eric, you should know by now it is impossible to engage reverse from 5th - there is a gate to go through from neutral only.
The HDi would have benefited from 6 gears, and some more BHP's
The guy following behind will have to replace his underwareEric wrote:Discuss possible outcomes
Ah it's probably just old boxes, I think Pug/Cit boxes get pretty sloppy after time.Malachy wrote:nothing wrong with pug boxes, most pug box problems stem from worn selecters which cost £40 to replaceEric wrote:French gearboxes anything is possible![]()
try a vauxhall/renault/rover boxes then come back and whinge about pug ones
Takes a while to get used to when they are all different doesn't itneildavies wrote:I was surprised when i got the coupe to find that reverse is to the left of 1st, via a lift up clip.
But on saying this, I've seen another HDi coupe with reverse in the 6th position.
The 405, 306 and 206cc we've owned have all been in the 6th position
