Im desperately looking to drop the 6 by 40mm (minimum) or 60mm if possible. What if any springs can i use? Will 306 springs fit for example?
Any info/help would be greatly appreciated
Thanks all
This is true. And the main reason for this is in my opinion the bad quality cheap lowering springs ( which you can usually tell by just looking at the spring and feeling it. Thin ones with neon colouring suck in most casesWelton wrote:Some chav-charriots have such hard suspension that the wheels loose contact with the road on bumpy corners and make the handling worse!
We dont have such a thing here in blightybargainbro wrote:good tarmac
M6 toll?TooT wrote:We dont have such a thing here in blightybargainbro wrote:good tarmac
not true. arb droplink is attached to the main body of the strut and is not affected by the ride height. ride height is controlled in the spring. any decent uprated shortened damper will have the arb droplink bracket welded where the original was.Welton wrote:
Many cars also require shorter drop links, some require modifications/shims to re-align the geometry of the suspension and wheels etc. When you lower a car it can falsely 'load up' the anti roll bars without shorter drop links giving a really weird ride etc.
mikey s wrote:not true. arb droplink is attached to the main body of the strut and is not affected by the ride height. ride height is controlled in the spring. any decent uprated shortened damper will have the arb droplink bracket welded where the original was.Welton wrote:
I´ve been trying to solve this one out for quite a while...but no one seems to know....steve_earwig wrote:I just thought I'd throw this one in here to get a big communal >huh??< from you lot: Can I get L O N G E R springs for my D9 and what do I need to know/take into account? You know, things like steering geometry, availability of longer dampers and should I fit casters to the luggage bars.
bargainbro wrote:even tried to e-mail the local dealer (haven´t heard back from them.....)
