can anyone tell the weight of a 406 sri engine or an estimated weight as im trying to buy a engine hoist for lifting the engine
cheers
Mike
engine weight
- mjcook1984
engine weight
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
- darrenwall
Re: engine weight
at a guess id say less than 150kg without the gearbox and probbably around 200kg with the gearbox attached
, i though most engine hoists are rated to at least 500kg's
just dip me in chocolate and throw me to the lesbians
Re: engine weight
it should be perfectly ok to pick one of them out as its only an 8valve engine with a turbo so on the scale of engines should be a fairly light one
- mjcook1984
Re: engine weight
ok thanks. just fort it might weight abit bit more due to its cast block
- niz406
- Admin <BR>Turbo God
Re: engine weight
well between myself and my brother we picked on up, loaded it into the back of a van, and then took it out again and placed it somewhere safe... I'd say it was about 250kg - 300kg with both manifolds, turbo, and ancillaries etc on...... the head is about 40-50kg on it's own!
Why a hoist and not an engine crane?
Re: engine weight
Crane/hoist same thing i think?niz406 wrote:Why a hoist and not an engine crane?
Mjcook why not hire one from Speedy or HSS?
