That would be a roller bearing. I'd be tempted to strip it and fit a grease nipple (remember them?) at the back.supafrisk wrote:Doh... ball race (but with cylindrical rollers)Welton wrote:What's with the rusty pellets?
It's not the same gearbox, manual at least. Maybe the same design and housing, but (some of) the internals are different. The diff is specific to the V6 and the driveshafts are bigger than the rest of the range - as I discovered when I needed a new CV boot...rapport25 wrote:I always thought the more paid for a car the more testing done by the manufacture![]()
406 coupe 3.0 V6 has the 2.0 gearbox and a sh*t load of compromises.
I have had many peugeots over the years and it is by far the worst peugeot i have owned 3.0 V6 SE manual coupe. The gearbox broke on mine and was told by a gearbox specialist that gearbox was not upto the extra power from the V6 and was the 2.0 boxmjb wrote:It's not the same gearbox, manual at least. Maybe the same design and housing, but (some of) the internals are different. The diff is specific to the V6 and the driveshafts are bigger than the rest of the range - as I discovered when I needed a new CV boot...rapport25 wrote:I always thought the more paid for a car the more testing done by the manufacture![]()
What compromises are there other than the keypad immobiliser and auto-closing windows (actually part of the immobiliser system)?
It's the same design as the 2.0 box, but not the same internals. The box is fine to take the V6s power. If it weren't there'd be none on the roads now and mine would be scrap as it probably spends more time on the sunny side of 4000rpm than under itrapport25 wrote:The gearbox broke on mine and was told by a gearbox specialist that gearbox was not upto the extra power from the V6 and was the 2.0 box![]()
his words not mine.
Parts for most cars are overpriced from dealers. There's no difference between the cost of parts for the 406 saloon, estate and coupe.Parts for the coupe very over priced
But it is a LOT more desirable to nick than a 406 saloon or estate, both of which are group 17 - not a lot of difference in premiums.and insurance group 18for a car that really is not that quick.
Can't say much here because I've not driven a coupe, but the saloon has nothing on the estate when it comes to handling. The estate has bulked up rear suspension and much better weight distribution. The extra 100KG over the rear really improves things a lot.Or does not handle very well even if you are not pressing on. And this car has upper and lower strutt braces so it should handle well. A V6 in a saloon far better option.
according to servicebox you must not fit a balljoint that hasnt got those three paint dots on its to prove its never been on a vehicle.....apparently......only thing is if it had been on a vehicle it would be in two pieces cos its gotta be pulled offsteve_earwig wrote:I suppose with that rubber seal, all the testing in the world can't age something by 4 years. I'm wondering if those things that look like paint dots on the seal on the new balljoint are to show it's modified.
Just out of interest, the Ford Pinto
