Just thinking here on future mods for my 406 exec turbo. They used to use the same engine in the btcc (XU10 J2TE). Or am I wrong was it the XU10 J4TE?????
How would I be able to get a list of mechanical mods done to the engine????
I used to be indecisive but now i'm not so sure.Lynne and Crow Never take life seriously. Nobody gets out alive anyway
lynneandcrow wrote:Just thinking here on future mods for my 406 exec turbo. They used to use the same engine in the btcc (XU10 J2TE). Or am I wrong was it the XU10 J4TE?????
If you PM me the last 8 digits of your VIN, i will be able to tell you what engine was fitted to yours. If you're happy to do so..
Was it not just a 2l 16v engine without turbo? Obviously highly modded, there have been BTCC parts (mainly carbon airboxs, etc) popping up on the 306GTi6 forum for the 306 BTCC engines, which I would assume would be more or less the same if they were NA.
The engine was an XU10J4, and you'll need some very serious metalworking equipment and skills to copy the mods, and then I wouldn't expect it to survive more than about 100 miles if you don't rebuild it every night...
I'm guessing at a lightened and balanced crank and flywheel, *massive* porting work to the head, maybe forged pistons & rods, inlet and exhaust manifold work, fueling work, raised RPM's ............
As Welly says plus throttle bodies with carbon trumpets, carbon airbox, mappable ignition, etc, etc. To bo honest you could probably get just as much power from the turbo engine if you're prepared to splash the cash.
Here's an ad which has had a BTCC spec engine fitted for the princely sum of £21k just for the engine alone! Motorsports Ad
Thanks for all the replys. I thought BTCC rules pre 1998 were that Turbo's were allowed and that at least 500 or more cars had to be produced and sold of the particular model fitted with the same engine??? Hence the old Sierra RS500 from the old BTCC days and the Goodwood Turbo Volvos in the same year. The XU10J4 engine was from a 306.
Is there any 406's fitted with XU10J4 engine's and why?? Also why did they use the old XU10 J2TE lump on the SRi as it was also fitted to the 405 and Citroen XM. Usualy manufacturers re-manufacture a new engine into a new car, do they not??? Uness they wan to exploit a well proven engine.
Is the 2l 16V lump in the 406 not an XU10J4? The GTi6 engine is an XU10J4RS IIRC. There's not much difference between the two, cams and exhaust/inlet are the main differences I think.
lynneandcrow wrote:I thought BTCC rules pre 1998 were that Turbo's were allowed and that at least 500 or more cars had to be produced and sold of the particular model fitted with the same engine??? Hence the old Sierra RS500 from the old BTCC days and the Goodwood Turbo Volvos in the same year. The XU10J4 engine was from a 306.
Nope, no turbos after *i think* the late 80s or very early 90swhen cossies were killing everything else. So they made it 2ltr 16v normal aspirated engines with a maximum horsepower of 300bhp, just like rally cars. This is why volvo never used the2.3 turbocharged T5 for BTCC, just the 2.0. It's also why BMW made a 6 pot 2.0 if i remember correctly. It did a lot of good in the real world too, because manufacturers had to make better designed, built and more efficient normaly aspirated engines in order to stand a chance. You can't polish a turd. Renault pumped more time and money into this era (remember the dominant lagunas?), which is why thier 2.0 16v normaly aspirated engines are so far ahead of everyone elses, even to this day.
Man: What shall i wear?
Woman: Oh for god sake, you're not a child, i'm sure you can dress yourself!
5 mins later.
Man: Right then, what do you think?
Woman: You're not seriously going to wear THAT are you?
Man: Well i did ask you!
woman: <sigh> Come on, let's go dress you PROPERLY...
Man: WELL I DID ASK YOU!
Not to mention very tight tolerances that didn't open up to proper spec until the motor was properly hot, hence them being knackered after a few goes as F1 style preheating of oil and coolant was banned.
If I remember right, BMW didn't use the 6 cylinder engines for Touring Car racing - they used the M42 engine from the 318is, bored out to 2.0. These were a much better & flexible engine to start with than the straight 6 - 140bhp from a 1.8 is still more than most manufacturers provide now!
The rules were a little bit flexible in that the car & engine combinations didn't actually have to be sold together, hence Ford using the Mazda V6 from the Probe knocked down to 2.0 from 2.5 in the Mondeos in 1993 - long before the Mondeo V6 was being produced.
As another point of interest, my father remembers Richard Longman from when he was growing up in Downton & Longman was well known for driving Minis faster than anybody thought possible at the time! Turned out a few years later he won the championship in one...
