Wanted 4 alloy wheel bolts and 4 steel bolts
selectcase
Post by selectcase »
Just had to put the steel spare on tonight as i have a puncture in the tyre on one of my alloys
whilst doing this i discovered i have 3 19mm head bolts and one 17mm head bolt on each wheel which is a pain :? other than the head size they are identical. they are for a 2001 406 estate with original alloy wheels - the studs have a flat washer and a taper further down the bolt shank with a 19mm head - i would also like a set of 4 bolts for the steel wheel in the boot
many thanks
will
omega
Re: Wanted 4 alloy wheel bolts and 4 steel bolts
Post by omega »
i think i can sort you out with both of these,will have a look tomorrow
can you collect?as postage will be high as they are heavy
selectcase
sorry for taking a while to reply
i dont mind paying the postage if you could give me an overall price thanks
