Radiator wanted
Nandad
Radiator wanted
Post by Nandad »
Hi
I need a rad for my Executive turbo estate (petrol). Caus the honycombe is falling out.
midsdaz
Re: Radiator wanted
Post by midsdaz »
Don't bother with 2nd hand I did and i ended up buying brand new cost me 40 from car spares but that was with trade but
Mines a 2.1 dt and looking at ur other post about this what do u mean by fittings ? On mine there's a metal collar on the pipe witch pushes in to the rad the top one comes out easy the bottom
One is a nightmare all I did tho is cut a line in the plastic where the metal bit sits then split it open not sure if urs is the same
Nandad
Re: Radiator wanted
Post by Nandad »
Hi
Been told its a XU10JTE engine.
The fittings look like a push in with a u clip locking ring.
The book advises new washers. Are they rearly neccessary or can I reuse old ones? Or can I use a jubilee clip fitting?
midsdaz
Re: Radiator wanted
Post by midsdaz »
The only clips on mine are like a horse shoe and ye i reused mine if its the same as mine u can't jub clips
