Working Speedo with 150k odd on the clock old one had 86k on the clock so it's done about 110k realistically.
Engine gearbox etc all spot on but due a service.
Planning to run it around till the 31st but then after that it's all yours if you want it.
Mot expires on the 9th September so you'll still be able to get it home.
Panels are mostly scratched or dented so don't buy it if panels are what you're after and the interior is a bit knackered as well but then it was bought 2 years ago as a £400 shed she learned to drive in.
Glow plugs occasionally need a whack to make them work when it's been damp.
Got all of its receipts etc from when we bought it so pretty much full service history before then.
Chassis requires a bit of welding on the sill and has a brake imbalance on the rear axel.
Yours for £150 and a twix
