WANTED - Sandvik SD7V16 1209 air con pump!
'Cause mine spat it's clutch splines out the other day and that means I can't even undo the front nut to fix it
Re: WANTED - Sandvik SD7V16 1209 air con pump!
I have a Sanden SD7V16 pump but a different model number.
If you post your car details I can check if they are interchangeable.
Cheers,
Steve
Cheers,
Steve
2003 406 2.2HDi SE Estate Manual - Sold
Stenasev wrote:I have a Sanden SD7V16 pump but a different model number.
Cheers,
Steve
I think quite often the other models have differing pulley offsets, but it's a D8 (1998 3.0L V6 Coupe)
