206 GTi 180 17" Atlantis Alloy Wheels
HimBigChief
Post by HimBigChief »
Any body fancy a set for their 406? They are off a 206 though so would need 10mm spacers and slightly longer bolts to fit (not included).
One of the wheels has 2 flat spots (top and left of the pic below), but that is the only one with any buckles, and they are not that bad so should be fine on a back wheel or you could get them knocked out. 2 of the wheels are solid centres, and the other 2 have centre caps. Now I assumed that 2 were from a 206, and 2 from a 307, however they are all ET28 (stamped on the inside of the rim) so I don't know what's happened there :? . They will need new Peugeot logo's, and if you were picky you could repaint them again as I didn't spend enough time getting the prep work right. The finish is ok, but get close to the wheels and you will see various marks and striations. Brand spanking new bolt-in metal valves and caps fitted aswell.
Looking for around £220.
All 4
Rim 1
Rim 2
Rim 3
Rim 4
Metal Valves
Atlantis Stamp
Flat Spot
Look mint on a 406... (right click on the picture and click on 'View Image' if you only get part of the image up)
Image Image
