2.1td lucas epic pump, lines & injectors
craighuckins
1.6 8v
Post by craighuckins »
diesel pump, lines and injectors from my '97 130,000 mile car, were working fine before ecu locked due to keypad fault...
Offers?
regards, craig.
Re: 2.1td lucas epic pump, lines & injectors
Hope you don't mind me poking my snout in Craig, but does this mean you're sorted with the Bosch pump now?
Is it better?
craighuckins
1.6 8v
yup, Bosch pump is on! Can't say if it's any better as I bought the car with immobiliser locked on for the princely sum of £250, so have only driven it with Bosch pump. However, I am now starting to play with the fuelling and boost settings on the pump and it is pleasantly spritely!
regards, craig.
craighuckins wrote:yup, Bosch pump is on! Can't say if it's any better as I bought the car with immobiliser locked on for the princely sum of £250, so have only driven it with Bosch pump. However, I am now starting to play with the fuelling and boost settings on the pump and it is pleasantly spritely!
regards, craig.
Probably satisfies most definitions of 'better' :)
Well done Craig 8)
