Garden tidy 2x 406 estates
Re: Garden tidy 2x 406 estates
Steve, you can lift up the gear stick gaitor, and reach under the lighter to reconnect it, but you need nimble fingers, plasters and a swear box....
Thanks Kelv,GingerMagic wrote:Steve, you can lift up the gear stick gaitor, and reach under the lighter to reconnect it, but you need nimble fingers, plasters and a swear box....
I think I will be buying an aftermarket replacement and cutting that rediculous connector off.......
Cheers Steve
My other Peugeot was a D4B
Hi All,
Sadly, I am back to square #1 with this COM2000 as again I have no side lights!
There must be something else causing these units to malfunction......
Cheers Steve
Cheers Steve
Ah sheet. Sorry to hear that. Mine is still here if you want anything else. Was your original one mechanically broken or was you side lights the problem? If you want sent your original one to me I can plug it in to test it.
Ian
Ian
99 HDi Estate 110 fast approaching 200K. edit: now 215K
Thanks for the kind offer Ian, the side lights have come back since, and then gone again!!
Will probably be moving it on now, let someone else figure it out!
Cheers Steve
Cheers Steve
