it will go behind the engine to the bottom of the turbo, so about the middle of the engine, the turbo sits on the exhaust manifold, gotta have that bottom pipe or it wont work, as far as posting it all i thunk to post the wing and a box with the intercooler stuff in seperate would be best.
this stuff wont weigh a lot just be large.
d9 hdi 90 rapier estate
Exhaust manifold at the back, theres not much room in there But the pipe goes from the bottom of the engine then upwards, is it just the rubber bit, this is part 2 in the diagram i assume, what is the part 1 that goes into the turbo?
but who should i send the parts with? any good delevery companies you can suggest.
not worried about part 1 thats cheap from the stealers, its part 2 im more concerned about that the part i need.
if you package the intercooler stuff in a box and send that as one and send the wing seperate id send it by parcel force that should be the cheapest and u can track it
ok then so ill get under the car tommorow for a good fight with this pipe.
I suppose the crude topic of price will need to be discussed. An intercooler and a wing. What price will you start at.
re edited the pic so it will be easier to explain.
these are the parts i need
FarmerPug wrote:ok then so ill get under the car tommorow for a good fight with this pipe.
pm me your starting price then i'll bid u like mike brewer
I got the cars specs off servicebox
Its a Hdi 110 as i had expected
First Registered in Dublin ? a bit odd ???????
Trim level Selection Pack
Badge LX
Body colour ege china blue
Was at a funeral this morning, got back to the car to pull it out, and it was bucketing with rain. So havent got it out, but i think its just one more screw holding it in.
this is the offending article:
all else is out, the wing is sitting safely in my wardrobe, and the intercooler in the garage.
FarmerPug wrote:Was at a funeral this morning, got back to the car to pull it out, and it was bucketing with rain. So havent got it out, but i think its just one more screw holding it in.
thats the one, it'll be held to the turbo by a jubilee clip and mabie some other bracket's
edit: if u look at the diagram it looks like there's 2 bolt holes and then the clip on the turbo thats it
A question i have listed an item on ebay, stated that postage will be to royal mail 1st class and someone has put a bid on it and emailed me saying they are from spain. But i only ship to uk addresses. Is it possible to post to an address in spain and get tracking and the thing where they must sign?
