I was breaking a car, but not anymore
Re: Im breaking a car
it could be the ecu. if you lift the switch in the middle can the full seat rise?
only the front will rise and go down.
this switch arrowed orange slides the seat back :lol: even if you push it up or down all it does is slides the seat back .
sounds like somethings been wired up wrong.
In my car the back of the base can go up and down, the front of the base can also go up and down.
Although when putting the seat down it does go back a small bit, just how the mechanism works.
nothing can be wired up wrong. it hasnt been retro wired.
a simple power cable to the ecu and thats it.
all my seats have original plugs fitted into the bottom of them ..
have you got memory on these new seats?
does it affect both seats?
perhaps its a motor issue?
seats have got memory but as far as i'm aware they dont work when you fit them into a car that didnt have electric seats in the 1st place.
few people i've asked all say switch problem. i will get a new one off woody 2moro why im only 3.5 mile away from his breakers yard ..
im not sure where the memory comes from. i think you must memorise it first.
Also in my car theres a bleep that comes from the com2000 to let you know its finished setting the seat and mirror positions.
i'm not to bothered about the memory to be honest.
i just want the movement working, it apears my heated seat also doesnt work.
i've yet to test the passangers side ..
well now, id contact the seller you got the ecu off.
i cant help anymore, i havent worked on my leccy seats so cant comment. But with the amount of wires under there a loose/bad connection is not impossible. Take the airbag faults i had when i got my car.
i will try a new switch today. got one off woody.
also forgot to mention when i arrived at the donor car for the leatehr seats the window was not in the door.
i said to the owner why have they not been covered up. he said it hadnt rained much
so god knows how long the drivers seat was getting water all over the switches /
there hadnt been much rain, ha. Its the uk rain is part of daily life.
Does the seat smell damp?
Can you take the switch out? Ive never did it to mine, but i think you could clean the contacts.
Watch out for really small springs flying all over the place when its opened.
frank my seatbelts arrived today mate..
thanks very much . :mrgreen:
plod
Post by plod »
I'm contemplating getting another switch
I've seen them on the bay for £25
1999 D8.5 HDi GLX - Sold :(
dave ive tried a new switch today. no luck.
the guy i got my ECU off is sending me another.
but to be honest im gonna use my switch and plug off my GTX seat and do away with the ecu
a switch and plug kit off a GLX seat will eliminate the use of the ECU.
you get 2 wires on the GLX switch. a simple pos and neg :lol:
then plug the orange 1 into drivers seat.
get rid of the white plug completely on the leather seat cos thats only for the switch.
see,, the switch from a GLX has 2 plugs on the end. orange and yellow
switch from executive has 2 plugs on the end, a white and green (green for memoery switch)
if you look at your passangers seat on your leathe,r that, like the GLX drivers seat has a orange and yellow.
so the switch from the drivers GLX will convert your leather drivers seat to be just like your passanger seat
2 simple wires for pos and neg :mrgreen: :mrgreen:
NO ecu :shock:
