Gear box wanted
sonicspanner
Gear box wanted
Post by sonicspanner »
Hi all, can any one help with a manual 5 speed gear box for a 2ltr hdi 90bhp 99T plate, has the ridged linkage bars, I think its the BE3 code for the box. I think my diff bearings are on the way out, there is also another chap on here how will need a box aswell (Vibration under acceleration) but I don't know what box is fitted to his car. My location is Telford Shropshire, but I also travel to Oxfordshire, where I work on shifts, but can travel to most places.
Cheers Paul 8)
omega
Re: Gear box wanted
Post by omega »
got a gearbox/ engine from a 1900 diesel dont no if it would be any good to you
sonicspanner
Re: Gear box wanted
Hi ya, could you post a pic of the gear box, then I can tell if it will fit my engine, I can't remember were the code for the box is, but am intrested if its the right one obviously.
Cheers bud, Paul
omega
Re: Gear box wanted
Post by omega »
sonicspanner wrote:Hi ya, could you post a pic of the gear box, then I can tell if it will fit my engine, I can't remember were the code for the box is, but am intrested if its the right one obviously.
Cheers bud, Paul
i have a look tomorra to see if i can see a number not sure about pics as im a bit of a teck no phope
Chaz
Re: Gear box wanted
Post by Chaz »
I have a 5 speed box from my wife 2.0 Petrol Turbo up for sale - any use?
sonicspanner
Re: Gear box wanted
Thanks for the offers of gearbox's, but unfortunatly peugeot had a vast number of box's fitted to there cars, the best discription of my box is a hudralic operated clutch, and has a horn shape shifter on the rear upper face of the box (as it would sit in the car) with a ball joint. To help with pics, you can either email them to [email protected], or text them to 07946603809. Hope this helps with sorting the right gear box.
Cheers Paul :wink:
Re: Gear box wanted
You can't interchange petrol and diesel gearboxes - the ratios are very different.
sonicspanner
Re: Gear box wanted
Cheers bud, that solves that one, he he, and I never even gave the ratios between petrol and deisals a thought, top marks to that chap, gold star is needed.
Cheers Paul
