breaking my 1997 2 litre saloon
hi guys im currently breaking my 97 saloon all parts available body panels all straight good engine and gearbox not after loads of money for it pm or call/text me on 07805425148
Re: breaking my 1997 2 litre saloon
im in bridgwater its dark grey
Jason, does it have the factory fitted key fob operated alarm system ,which has the internal movement sensors,and if so does it still work when triggered. If it does,I need the "Texton" sounder unit which is light grey and has a key operated switch on the end of a black cable attached to it. It should have the number 96182344(Texton) on it. On my 1996 2Ltr LX saloon,its mounted under the car car,behind the o/s rear wheel arch in side a vented box. I also need the Texton alarm control unit which is mounted behind the glove box.Unfortunately ,the glove box has to come out to gain access to it.
I have texted you today,but you may ring me at work on 07974984630 during the day ,or 01788 560665 evening.
Paul
Paul
MK1 1996 2Ltr 16v Petrol LX, 167,000 miles,was aiming for 200,000.
