My 406...
Bailes1992
My 406...
Post by Bailes1992 »
As much as I like my 406 I've decided it's a tad too big and I fancy a Focus Estate or 306 Estate.
It's a Peugeot 406 1.9D-Turbo in L Flavour.
It's a family estate so comes with 7 seats and an electric sunroof.
I've fitted a new instrument cluster at 109,200m exactly with the new cluster showing 124,635m. The new cluster includes a rev counter and oil gauge. The mileage is now showing just under the 126k mark.
The car has a Bosch pump and can be run on Straight and Waste Filtered veg oil.
The CAT has gone but I'm using it as an excuse to get it Decatted.
History with the car...
The car was built 16th June '98
7/5/99
1st Inspection and Service
12/01/00
Service
20/08/00
Service
17/05/01
Major Service
4/2/2002
Major Service + Timing Belt
22/12/2002
Service + Brake Fluid Change
12/07/2003
Service
The car was off the road from 2003 till 2005 (I have all the tax discs from 2003)
4/3/05
Full Service
MOT
Brake Discs
New Bads
Repaired Hi Level Stop Light
Repaired Numberplate Light
3/3/06
New Clutch
Welded Exhaust
5/3/07
New O/S Antiroll Bar
New link arm
Service
Adjusted rear brakes.
20/11/07
New rear brakes.
7/03/08
New O/S CV Gaitor
New Clips on N/S CV gaitor.
26/03/09
New O/S spring.
4/03/09
Ajust rear breakes.
Weld rust on O/S sill (This looks a little rough).
Service
This is when I took ownership of the car.
29/03/10
New engine mounts.
13/04/10
Replace N/S/R Lower Arm Outer Bush.
Replace front Antiroll bar link arms.
Replace N/S Driveshaft
Replace No2 Injector Seals.
I also have every MOT Certificate and it's never failed.
Bad Points:-
Holes in Dash from where equiptment has been screwed down.
Gearbox can be a little notchy, mainly 3rd gear but it's very easy to get used to it and after a few miles you have no problem with it.
Wear on drivers seat.
Bad repairing of O/S sill.
Few dents in the boot.
Starts and hunts for idle for 5s (seems quite a few aged 406s and 306s do this?)
Other than that the car drives perfectly, runs well and pretty smooth for an old diesel.
I bought the car for £700 and spent around £700 on it since I had it.
Therefore looking for around £900ono. I will be putting the standard speakers back in and taking the Sub and Amp Out. If you want to keep the radio that I've fitted I would like an extra £60 for it otherwise you will need to bring your Ipod for the journey home :lol:
PX for a Focus 1.6 or Diesel Estate. 306 DT Estate or Hatch. Any other small hatch with 1.4 - 1.6 petrol or diesel.
