Its a subtle but modern twist on an otherwise bland area of the car.
I have enough material left to produce another one, this is proper pre preg carbon fibre,NOT the sticky back fake stuff hence the price.
Will be cut and drilled to fit correctly, you will need to remove your badge from the car dismantle it, and replace the black part with this.
Then re assemble and re fit to the car.
You will get.
Carbon fibre shaped to fit
trim tape to seal badge back on the bonnet.
Two new stainless steel nuts.
Due to cost of materials and the time it takes to trim up im asking for
£17.50 deliverd
for the one i have available.
If requird i could make more depending on numbers.
![Image](http://i5.photobucket.com/albums/y162/swampys16/DSCF2219.jpg)
is how the finished article looks
PLEASE BE AWARE THIS IS FOR THE COUPE BONNET BADGE IM UNSURE IF IT WILL FIT SALOON BADGES
