it will go back into a D9 but i cut the wires off that connect to the airbags on the seats
so the front airbag seats wont work unless you wire them back up
also if your fitting this into a D8 you will need to transfer the rear back section onto your D8 frame, this is easy and i will show you how
all in all it will make a good interior and its black, not crap grey
you may need to use a few small bits off your old seats. ie, the side plastic bits at the bottom of the front seats, i have 2 but 1 of the clips is snapped on both
with a bit of tlc it will be spot on
there is 1 small fag burn on the drivers seat and the rear bottom bit (not to noticable i coloured them in with black marker
feel free to collect this interior free of charge (a few beer tokens would be good)
i like fosters
