Hi,
A drunken yob crashed his crappy Rover into my 406, so I am now selling off the parts I don't need for my new one.
N/S damage.
Immaculate pre accident.
Has black leather interior, Samarkand metallic blue.
88000 miles
located in High Wycombe, Bucks
Mike
Breaking W reg 406 V6 GTX saloon
Re: Breaking W reg 406 V6 GTX saloon
Awww bugger
I hope he was insured.
- waue1978
- HDi don't believe it!
Are the leather seats memory seats or just electric adjustment?
Hi,
They are electric adjustment. But no memory function on this car.
The memory function can be added, but an ECU and switch unit is required which is not fitted on this car.
Mike
Mike
- waue1978
Memory is actually not wanted in this case. Are the seats in good condition & if so, how much would you ask for the interior?
The seats are in good condition.
They are complete with 5 headrests,airbags & heater switches. The motors and heaters all work correctly.
Front Passenger side armrest is not attached, not investigated why yet, but I expect I can fix that.
Very slight wear on drivers side bolster-but much less wear than you often see on a 406. The colour is intact. Certainly not worn through.
Rear N/S seat bolster leather is a bit crumpled where the door had been pushed against it, but otherwise is undamaged.
I expect the crumpling will improve now I have moved the door away from it.
I can take photos and email them if you want. Loads of other parts available from this car.
£100
Mike
edit: I have the door cards, but 2 are cracked. Not looked into how badly yet.
£100
Mike
- waue1978
Sounds pretty good. Forgot to ask if the seats have the airbags in them though as I forgot that W reg may be before they were fitted.
seats have air bags .
cheers
PS Your posts shows an estate. I think the seats are different in the saloon.
I do have the leather door cards, one needs fixing
cheers
