I was breaking a car, but not anymore
I bought myself a breaking car, just to give it a go, and to get myself a few parts, but i dont need them all so heres the car:
its a 2000 hdi 110, its not working right theres a problem with the fuel system (fuel pressure regulator) but im breaking the rest.
ive kept all the plastic rivets, the two top corners of the centre console, a few nuts and bolts, but apart from that the parts are available.
Re: Im breaking a car
is there a Cd changer in it mate ?
ah, i went looking for it, found this:
some sort of bucket, needs a damm good clean out. It was full of nails, actually good nails but unfortunatley no cd changer. Cd player up on the dash though.
on a mention of some of the stuff i doubt ebay sells too often. I have the glovebox light and switch taken out, with the wires. As well as the switch for the handbrake switch and the airbag ecu which did not display any faults.
jamjar1383
Post by jamjar1383 »
ok farmer p im after a bit but it would need posting,
the list
passenger wing
intercooler and piping inculding the elbow from the inlet
driver side headlight cap that sits on the back of the light (coverd the eletrics of the bulb)
d9 hdi 90 rapier estate
thanks for looking mate,
jamjar1383
all the parts i need are marked in red
i assume the intercooler and attached pipes.
are you looking a MAF sensor in that also?
If any of you wants parts send me a PM, ill remember better.
jamjar1383
no dont need the maf, just the parts for the intercooler and the inlet elbow
Oh oh... Steering wheel, airbag and steering column please! :cheesy: (don't need the ignition barrel, etc. though)
Is yours not com2000 then?
Oh.. uhh... Is the steering column different on a pre-COM2000 car?
Yep, the bit that matters anyway, so is the steering wheel.
jamjar1383 wrote: driver side headlight cap that sits on the back of the light (coverd the eletrics of the bulb)
i nabbed that one i had none either.
But the steering rack, youd need to be sure it would fit, i can see for comparison the 2 cars have different steering wheels and of course the com2000
I'm sure those caps are the same D8&9 and peanuts from the stealer's.
