d8 exec saloon 2.0 petrol breaking
as above its a blue saloon with cream leather complete car so let me know what you want
no radio/cd changer
no radio/cd changer
Re: d8 exec saloon 2.0 petrol breaking
are the door cards leather nigel ?
probably be cream anyway but worth asking
no they not leather think its only d9s that have leatherGary406 wrote:are the door cards leather nigel ?
How about the trip computer and wiper stalk?
nigel
im after the steering wheel and the speedo and gauges
jolly green giant 1.8 16v LX estate
the clocks are fine but the steering wheel is well worn
are you sure you want these as i took those other parts off for you and never heard back from you.
after outer rubber door window trim, the rubber ones that are at the bottom of windows on doors.
which door? front?left/right?ronnyp wrote:after outer rubber door window trim, the rubber ones that are at the bottom of windows on doors.
do they just clip in or do you have to take window out?
cheers
that peice of trim just slots out yes but its stuck to the door on the pillow
front and rear drivers side, they should just clip in
will have a look to morow and let you know
the front one is off no proplem,but the rear is not going to come as it joins the window rubber so you would have to take the quater window out.the other option is that i could cut it where it joins the quater window rubber.let mw know your thoughts.
thats ok and if you can salvage the clips that would be good if not no probs
can you pm your phone number pleaseronnyp wrote:thats ok and if you can salvage the clips that would be good if not no probs
