rear wiper motor Wanted
Looking for a rear wiper motor to fit a 406 executive estate V reg 1999 its the one without the blue resistor
Re: rear wiper motor Wanted
What is wrong with the original ? mine stopped working so i took it out
and stripped the whole mechanism , it had water in it and had basically
siezed . Cleaned it all up re-greased it and good as new .
dont know whats up with it, just will not work. the motor gets warm but just won't wipe, auto electrician said it needs a new motor
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
if its fubar then there is no harm in stripping it down and giving it a clean lube and rebuild, did mine and it was full of all sorts of crap that was preventing it running then if in the long run , like mine, it still doesnt run its cost you nowt and you still need to just get a replacement.
That was my thought, you can't make it any worse
The shaft was seized on the one on my D8, I pressed it out (the casing's monkey metal so use a tube), cleaned it up, gave it a lube and it worked fine.
I'll give it a try during the week
tried all that and still wont work so still looking for a motor
