Rear brake calipers
Rear brake calipers
Hi,
Does anyone have a driver's side rear brake caliper "lying around" for the HDI 110 saloon model? Mine is completely seized :( I tried reconditioning it a few years ago and it seemed OK for a little bit but is now worse than ever. So, before I turn to eBay .... :oops:
Also, will one from a Coupe do the job or they different fits (not at home, so no idea of my Service box login).
CJ
boombang
Re: Rear brake calipers
Post by boombang »
All rear calipers are the same.
I went for ebay in the end, one was seized so they gave me most of the money back. Then I used some penetrating lube and a vice, managed to free it off.
plod
Post by plod »
The ones I have aren't particularly good, as I bought a second hand pair off Omega, had them reconditioned and fitted to the car, so they are the ones that came off, but the reason they came off was they were seizing up
I'm pretty sure when I looked then, the rear calipers (with rear brakes with discs) were the same 4400 H8 and 4400 H9 across the range, and a quick look on SB seems to confirm this
1999 D8.5 HDi GLX - Sold :(
grasmere59
Post by grasmere59 »
I have one in the garage but not sure which side,i had a siezed one and managed to get a pair of new ones at a good price so changed the pair but the the one i had left was fine,i'll have a check and let you know.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Great, thanks! :)
plod
Post by plod »
Shame it wasn't the fronts as I have a brand new pair
grasmere59
Captain Jack wrote:Great, thanks! :)
Sods law strikes again,the one i have left is a N/S one,sorry mate :(
Boo! OK, thanks for looking :)
grasmere59
If you'd have wanted a N/S i would have had the O/S,you could put money on it!
What if I pretend I need the NSR one?
grasmere59
i'd probably find an O/S front in the garage :lol:
Got one from Ade for £25 delivered :D
Now... anyone have an intercooler for the 110 as mine is leaking....?
Cue radiators, condensers etc....
grasmere59
I have one,i was keeping as a spare for my old 52 Rapier but my Exec came with a newish one so i don't think i'll be needing it.Bit of a pig to change but it is possible to do leaving the rad and condenser in situ.
Is it a pig? Looks easy... undo top and bottom hoses, pull it out and ... no?
grasmere59
When i say a bit of a pig,if i remember right when i helped a mate of mine change his a long while back it seemed awkward,if i remember the bottom outlet of the intercooler snagged on the rad shroud and we had to trim a chunk of it off to clear it,it was an older 406 110 so perhaps the later ones are different.
