406 sri turbo mot failiure
jason j
Post by jason j »
my p reg 406 turbo, engine runs perfect and body work is in good condition failed mot on front brake discs (below legal limit) and rear suspension bushes.
Only thing missing is the standard dump valve as it got broken when some twat took it off.
car drives perfect apart from turbo will not spool up due to there being no dump valve.
sensible offers as needs to go by thursday ( scrap yard have offered £250 as a ball park) ideal if you can do the work for a cheap car or if you want engine loom etc for a conversion.
Birmingham area.
Foxy
Forum Admin<BR>Know it all
Post by Foxy »
Somebody could buy this and buy my 406 and put them together to make 1 very nice 406!
Used to own the finest 406 in the UK - RIP
It'd be a shame to have it scrapped - it looks lovely (apart from where someone's welded a baked beans tin to the exhaust :P ). If I had somewhere to park it off-road I'd take it off your hands for spares, especially as I've got to fork out for new tyres next month, and your alloys look a lot better looked after than mine!
One request though, if you do end up scrapping it, can you scavenge a small piece of throttle linkage off it for me? I can do you pics, but it's a short rod about 4" long with a ball joint at either end which is attached to the circular disc the accelerator cable ends on (under the bonnet). Tenner?
tux2006
Post by tux2006 »
I would take it off your hands if i had any money...and if I wouldnt get murdered for buying another car :frown: :frown:
Assumptions are the mother of all F**k ups.
jason j
Post by jason j »
Got to go guys c'mon someone must want to have it rather than it be scrapped it is a good solid car apart from the faults listed which are easy fix's.
niz406
Admin <BR>Turbo God
Post by niz406 »
If they are only brakes and bushes, then why don't you fix it??? Cost of repairs... like under £100 approx if you do it yourself!
What tax is on it?
Have you tried to block off the hose to see if the turbo spools ?
Niz406
jameslxdt
Post by jameslxdt »
what tax is left on it? and if any, how much mot remains?
if you decide to break it ill have the engine loom :cheesy:
jason j
Post by jason j »
niz406 wrote:If they are only brakes and bushes, then why don't you fix it??? Cost of repairs... like under £100 approx if you do it yourself!
What tax is on it?
yes runs perfect mate had a bailey DV on it but took it off to ut on other car.
Already got one sri turbo and bought the second one before consulting the wife :evil: she likes the white one best so the grey one goes.
Do not have the time to sort we are moving to manchester pretty soon and need to clear stuff away.
James no tax or mot but have the fail sheet to show how easy it will go through its next mot.
jameslxdt
Post by jameslxdt »
would it make a 200+ mile drive?
jameslxdt
Post by jameslxdt »
did the turbo spool with the bailey DV?
niz406
Admin <BR>Turbo God
Post by niz406 »
Darn just seen the tow bar :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
James the answer which you seek is yes ! :D
Niz406
jason j
Post by jason j »
Easily do a 200 mile drive even without a dump valve fitted ( would advise putting one on tho its faster :P ) the only reason it will struggle is the cooling fans do not always kick in niz reckons £45 for new motors but as long as you are not stationary for ages( 10 min plus) the temp is rock steady and comes right back down once moving again and sits just under half.
jason j
Post by jason j »
a tow bar like the aa use would be s better idea like atow rope but a steel scaffold bar!!.
niz406
Admin <BR>Turbo God
Post by niz406 »
James,
For £250 its well worth it... I have a bosch std bov you can have if you need it or a cossie grp A BOV??
Cost you a max of £150 - 200 to fix then away you go! Get modding the turbo !
Niz406
jameslxdt
Post by jameslxdt »
already have a cheapo dv i bought for my old 306 td
i think this will be the way to go as i proper fudged my car today
i will have to check my finances as i just went on a spending spree for my now fudged 40shed
