I'd rather someone could use these than scrap them....
Any takers???
Above edit 10th dec.
These were almost brand new when I took them off to replace with grooved and drilled discs to see if it would stop the infamous Brembo squeal (needless to say, it didn't!).
Anyway, they've sat in my shed for the last two years and I'm having a clear out (actually on the orders of the missus - divorce is too expensive so I'm just doing what I'm told....).
So, barely worn but with some surface rust from sitting around for ages - you could wire-brush it off but it will go in a few brake applications anyway. I've not checked but they will be pattern parts, not original brembo.
You'll need to come and collect from Bedford (MK40) - make me an offer... Derisory as you like (or swap serviceable 2.2 HDI MAF sensor) as they'll probably end up in landfill unless someone can make use of them soon.
Cheers
P
Discs and pads for brembo calipers - free....
