1999 406 HDI IGNITION BARREL AGAIN!!!!
womble171
Post by womble171 »
Hi guys
Has anybody got an ignition barrel (and key) of a 1999 406 2.0 hdi they can sell me please?
The one i sourced a few weeks ago has packed up on me!!!!!
Failing that, is there anyway to cross the wires so i can get the car running, need it
for work as i got a few jobs on??? CAn upload a pic of the wires if anyone got any ideas :?:
Neil...
Re: 1999 406 HDI IGNITION BARREL AGAIN!!!!
edit; ignore that.
no one listens anyway. :frown:
womble171
Post by womble171 »
Sorry lozz you have lost me there??
womble171
Post by womble171 »
Sorry mate, bit slow on the uptake there, been a long day....
It's well knackered mate, the plastic Y is well an truly cooked.... :(
sorry for late reply,
ive been hunting for some diagrams, (failed on that one,)
on the end of the ignition Barrel where the wires go in,is there a White cap,. Aka Black cap.
not sure if you can black cap these,
have you got an old ignition barrel around?
have alook and see if the barrel can be black capped, if you know what imean., ??
see picture.
note: picture/s will be deleted shortly,
http://www.ebay.co.uk/itm/PEUGEOT-406-2 ... 2332b22e8a
if its same as that :roll: :arrowu:
then there you goes, you wouid have to leave ignition barrel on after removing cap, put key in ignition for imobilser to shake hands with,
make sure - steering lock in barrel aint iffy tho, !!
womble171
Post by womble171 »
well it did look like your pic mate, but now it looks like this!!!!!
Just had a look at your link and mine is different, mine has 3 connectors on it :(
Ah rite its that whats Bolloxed then,
how did you mash that up ? :lol: :shock: :?
No way round it other than Bridge in the wires,
id be tempted to just bridge the wires with car fuses just to test,. (work out whats what,)
yellow with yellow orange with orange blah de blah.. iguess the two high post ones are the ones that bridge to get starter motor whirling
womble171
Post by womble171 »
It wouldn't turn when I opened the ignition up an seen the Y was goosed so I though what the hell, got nothin to lose!! Was kinda hopin I could just turn it with a big blade screwdriver but when I tried opening it everything seemed to fall apart :shock:
Will have a go at bridging if I can't source a new barrel an hope I don't fry the ecu :roll:
womble171
Post by womble171 »
stealthe
Post by stealthe »
Suffered the same problem on one of mine. The two curved contacts feed power to the blower fan, I believe. Run the fan on full and they heat up, melting the plastic casing and jamming the switch. Forcing the key to turn tears up the 'Y'. I went to a local french car breakers and the let me trawl the wrecks for the wiring loom. There are several different looms just to make life difficult.They have different plugs, I don't know if they could be rewired. Good news, your key and barrel are OK (unless you damaged them getting the out.) so you don't need a lock set.
An early indicator that you have this problem is a hot key when you take it out of the ignition.
stealthe
