307 alloy wheels.
- lozz
307 alloy wheels.
For sale
4x pug 307 alloy wheels.. 16 inch.
Bought these to fit on a 207 but they 'scrub on the rears..so they're no good to me
Offers ..over 50 notes the set.
Location Manchester.
Re: 307 alloy wheels.
any pictures??
- lozz
Hi mate
Here's the link I bought them from hopefully it will work at your end
http://www.ebay.co.uk/itm/121423336784? ... EBIDX%3AIT
the tires still on as well? if so ill give you 50 for them. see if they fit the coupe
- lozz
Yeah tyres are still on..
Rims are not too bad they just need a good scrub..
And a tidy up.
And a tidy up.
where in manchester are you?
- lozz
On the outskirts of Oldham.. not far from ashton-u-lyne
- highlander
- PowerFlow Shill
Wheels off a 307 will need spacers in order to keep the same track width on a 406. Not much, mind - can't remember the difference between 307 offset and 406 offset.hucky wrote:the tires still on as well? if so ill give you 50 for them. see if they fit the coupe
I had 307 "Apollo" (7-spoke) alloys on my old 406 saloon - the PCB (4x108) and hub bore (65.1mm) are the same between the two, so they fit just fine; they just sat further inside the wheel arches than the stock 406 steel wheels did. Spacers weren't necessary, but would have been nicer looking. 10 - 15mm hubcentric spacers would do a decent job.
Those wheels will look nice on a 406 though!
I have a set of 20mm hub centric spacers for sale if you're interested?
Std 406 wheels are 18mm offset, coupes are 12mm offset,
307 are 27-31mm offset so you need 20mm hubsentric spacers to run 307 wheels on a 406
10-15mm at the very least that's why they rubbed on lozz's 206
Hope this help's DDD.
2006 BMW e61 535d m-sport
run's for cover
- lozz
Yeah they 'rubbed on rear wheel arch liner's
I didn't fancy messing with 'spacers... gutted really as there nice rim's.
Just need em gone now as there in the way...
If there not gone in week or so I will cut the tyres off and take them to the none-ferous bridge of weighs'.
First 40 notes takes em'
Your'll only get a fiver a wheel lozz, trust me I know
Stick em on flea bay for £60 buy it now, they'll go
run's for cover
- lozz
I don't bother with eBay mate
I've weighed a fair few alloys in they is worth around 12-18 quid a rim'
If you've been getting a fiver for them you've been getting ripped mate.
They isn't worth much with tyres on mind they deduct 3-4 quid a rim if tyres or on..
These wheels is to good for scrap tho I'd sooner not weigh em in what ever there worth..
