406 v6 3.0 for sale
406 v6 3.0 for sale
Tel 07539240085 for more info.
- DaiRees
- Site Admin
Re: 406 v6 3.0 for sale
You've got a better chance of selling it if you give a bit more info and some pics.
Speaks for itself?
Registration number: R466VAW
Mileage readings are currently only available for MOTs done from 1 August 2011.
Vehicle make PEUGEOT Vehicle model 406 Date first used 1 August 1997 Fuel type Petrol Colour Red
MOT history of this vehicle
Test date 30 July 2015 Expiry date 6 August 2016 Test Result Pass Odometer reading 142,398 miles MOT test number 3366 9151 5478
Test date 7 August 2014 Expiry date 6 August 2015 Test Result Pass Odometer reading 136,978 miles MOT test number 7650 0971 4256 Advisory notice item(s)
Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Test date 2 August 2013 Expiry date 1 August 2014 Test Result Pass Odometer reading 133,475 miles MOT test number 3053 1461 3471 Advisory notice item(s)
Nearside Front Shock absorber has a light misting of oil (2.7.3)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Test date 1 August 2013 Test Result Fail Odometer reading 133,475 miles MOT test number 3495 2371 3247 Reason(s) for failure
Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Test date 20 July 2012 Expiry date 31 July 2013 Test Result Pass Odometer reading 129,769 miles MOT test number 3788 9250 2277 Advisory notice item(s)
o/s n/s front brake discs slightly worn
Test date 19 July 2011 Expiry date 31 July 2012 Test Result Pass Odometer reading 125,756 miles MOT test number 8965 4070 1242 Advisory notice item(s)
o/s n/s rear brake discs slightly worn
o/s n/s front brake pads slightly worn
Test date 26 July 2010 Expiry date 31 July 2011 Test Result Pass MOT test number 3239 7790 0295
Test date 30 July 2009 Expiry date 31 July 2010 Test Result Pass MOT test number 3119 7181 9422 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Test date 15 July 2008 Expiry date 31 July 2009 Test Result Pass MOT test number 2742 0749 8485
Test date 31 July 2007 Expiry date 31 July 2008 Test Result Pass MOT test number 2314 3251 7215 Advisory notice item(s)
Nearside Rear Direction indicator slightly discoloured (1.4.A.2f)
Test date 26 July 2006 Test Result Fail MOT test number 1824 8770 6230 Reason(s) for failure
Offside Rear Tie bar/rod has excessive play in a ball joint (2.4.G.2)
Offside Front Brake hose twisted (found during steering lock to lock check) (2.2.D.2b)
Test date 26 July 2006 Expiry date 31 July 2007 Test Result Pass MOT test number 2111 9780 6292
