Its not something I want to do but my brakes are binding and it is costing me about 10mpg, is it a difficult job to do? are there special tools required? I replaced the rear discs, pads and shoes a couple of weeks ago but they are still binding, I am going to replace the discs and pads on the front as well when I do service the calipers but I am looking for some advice please chaps, also when I do service the calipers I will be replacing the break fluid, any recommendations? cheers in advance.
Nick
brake caliper overhaul
if you don't know where your going, any road will take you there
- 2.2 16v
306 forum guy wrote: Any signs of wear? f*ck it off in the bin
i had to redo one of mine, my biggest problem was that pug will sell you the seals but not the pistons. So i had to find one in scrap which isn't that easy to do, four scrap yard before i found a 406 with rear disks!
The job it self is not too hard, if they are binding the union on the brake pipe into the caliper may be ceased, easy to remove at the next union. The pistons will come out with a good pull. try to keep them square in the caliper or else they will stick.
1997 Honda Prelude 2.2 VTi
