I am currently breaking a 96 Excutive and have for sale the much sort after Black Leather Seats (without the old fart ribs on them). The seats are in very good condition with no tears or burns and only mild wear on them.
What you will get for your money is front and rear seats 5 x black seat belts centre console the heated seat switches and the memory ecu.
Only visible faults are the drivers armrest plastic clip is broken and the plastic surround that goes around the memory buttons is missing. I cannot check if the heated seat pads are ok but everything else works fine.
Now the bad news i would like £150 for the above and you have got to pick it up from Northampton.
I also have 5 Alloys and Tyres in good condition and the rear shelf with sun blind and any other bits of the 406
Leather Seats for sale
Hi mate we had a bit of a saga taking them off and the end result was not good,2 problems the inlet pipe on 1 jet has broke and the outlet pipe on the pump has also snapped.I think that they can be glued together again if you want to try,just let me know all they will cost is postage to you.Sorry for having hands the size of mallets!!(they do have good uses at times)
