[FOR SALE] 406 Turbo Bits
niz406
Admin <BR>Turbo God
Post by niz406 »
Off the top of my head ! !
  • Bosch MP3.2 ECU
  • Turbo Electrionic Valve Controller
  • 2 x Fans in shroud with 3 new relays - less than 20k miles old
  • Radiator less than 2 years old
  • Lots of other bits - Just ask.
Niz406
Re: [FOR SALE] 406 Turbo Bits
How much for the fans?
I also need the throttle linkage, thermostat housing, airbox & hose, & top rad hose off the top of my head.
It may be worth me driving up to see you!
niz406
Admin <BR>Turbo God
Post by niz406 »
teamster1975 wrote:How much for the fans?
The fans or the shroud? if just the fans that makes it easier for me ! !
Throttle linkage check
Thermostat housing or just the black plastic cover?
Air box check - Hose Uncheck
Top rad hose been on the car a year and lower rad hose less than 8 months old.
A drive from Surrey is a bit far mate... postage will probably be cheaper ! !
Have a think and let me know what you come up with and I will see what is left !
Niz406
niz406 wrote:The fans or the shroud? if just the fans that makes it easier for me ! !
Just the fans I guess. It's only one that isn't working.
I'll take the linkage! I'm using cable ties at the moment!
I've got a coolant leak from the thermostat area; I'll take your advice, would it just be the cover & o-ring or the whole lot?
I'll take the airbox, bummer about the hose; mine is bound with insulation tape!
I'll take the top rad hose (I replaced the bottom one earlier this year when I did the rad)
Let me know how much you're looking for & postage!
I need the spare wheel changing kit (jack etc.) but it wouldn't be worth the postage :(
Roy
Post by Roy »
Is it a saloon or estate,?? as I'm after the boot lid liner cos my lights let in moisture and the boot lid gives me condensation. :oops:
2003 SE 110 HDi
niz406
Admin <BR>Turbo God
Post by niz406 »
Its a saloon Roy
Niz406
niz406
Admin <BR>Turbo God
Post by niz406 »
teamster1975 wrote: Just the fans I guess. It's only one that isn't working.
Ok so two fans...
Throttle linkage..
Airbox..
Top Rad hose...
£50 + postage and pay pal fees, unless you want to get a courier to collect
As for the thermostat area, it could be both... the cover new from dealer is £12 approx and the gasket is a couple quid... do not buy a thermostat from a motor factors and try and use the supplied gaskets, they are not thick enough, the leak will just return.
Niz406
Roy
Post by Roy »
Does it have a boot liner,?? if so how much are you asking for it.??? although I live in Gods Country, {Wales} I'm working at the moment in the dry-dock at Penzance. so it would have to be posted.
2003 SE 110 HDi
niz406
Admin <BR>Turbo God
Post by niz406 »
Roy wrote:Does it have a boot liner,?? if so how much are you asking for it.??? although I live in Gods Country, {Wales} I'm working at the moment in the dry-dock at Penzance. so it would have to be posted.
It has all of the boot carpets, in black, boot lid liner, side liners, and floor liner... the boot carpets are immaculate.
You sure you don't want all of it? What colour is your boot carpet?
Niz406
Roy
Post by Roy »
Niz
It's only the boot lid liner I'm after, as I have a 8mm corrugated rubber mat all over my boot to stop my tools sliding about and the sides are OK. It's just the lid liner to stop condensation. {I'll have to get around to siliconing my lights one day.!!!!} :oops:
2003 SE 110 HDi
mjcook1984
Post by mjcook1984 »
metal inlet manifold
SRI 306 project On Hold Due to Baby and Missus sucking my wallet dry
Wooden island tailpipe
Corby Trouser Press
niz406
Admin <BR>Turbo God
Post by niz406 »
Roy wrote:Niz
OK let me find out how much to post !
Give me £10 for the carpet and panel clips.... and then postage and pay pal fees if you have pay pal.. that sound ok?
Niz406
