Hi there im trying to find some parts for my facelift 406 110 HDI.
my drivers seat recently broke so im after an electric drivers seat. A grey one would be brilliant but i suppose i could always swap the cloth.
My fuel flap has broken, meaning it wont open when i pull the lever from inside the cabin. i did try guling it but with no joy. if you have one in navy blue that would be great.
im also looking for the seven seat conversion as well.
there are a few other bits id like but dont want people thinking my car is falling apart, its just that i have decided to give her a little tlc.
cheers
Pete
07833450431
parts wanted please
- 1.6 8v
parts wanted please
Pete.
- puggy
- Resident Pervert
Re: parts wanted please
Cutting down the spec on your posts too, Puggy?puggy wrote:.
- Site Admin & Mad Biker!
This should sort the fuel flap!PeteL wrote:My fuel flap has broken, meaning it wont open when i pull the lever from inside the cabin. i did try guling it but with no joy. if you have one in navy blue that would be great.
djp30djp wrote:Same thing with all four of mine. after trying various bits of foam etc. I found the best way to fix it is with the spring from a wooden clothes peg. Just slide the hinge pin up as far as it will go, it can be tricky getting it past the little retainer thing at the top with only 2 hands, insert the spring & push the pin back down through it.
- puggy
- Resident Pervert
OOOooooooohhhh You !!!! LMFAOdogslife wrote:Cutting down the spec on your posts too, Puggy?puggy wrote:.
